Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 12 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Remove the battery.
Removing the battery
  • Remove the battery.
  • If your replacement battery came in a plastic sleeve, remove it before installation by pulling it away from the the ribbon cable.
  • Before you adhere the replacement battery, temporarily reconnect the battery connector to the motherboard socket. This ensures that the battery is properly aligned in its recess.
  • Adhere the battery, disconnect it, and continue reassembling your device.
  • During reassembly, make sure the battery is seated firmly against the rear case. This will prevent any damage to other components when reinstalling the front panel assembly.
  • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
Saca la bateria.
Si la batería de reemplazo vino en una funda de plástico, quítala antes de la instalación, retirándola del cable plano.
Durante el reensamblaje, asegúrate de que la batería esté sentada firmemente contra la carcasa trasera. Esto impedirá cualquier daño a otros componentes cuando vuelvas a instalar el ensamblaje del panel frontal.
Realiza un restablecimiento completo. después del reensamblaje. Esto puede prevenir varios problemas y simplificar la solución de problemas.
[title] Removing the battery
[* black] Remove the battery.
[* icon_note] If your replacement battery came in a plastic sleeve, remove it before installation by pulling it away from the the ribbon cable.
[* icon_reminder] Before you adhere the replacement battery, temporarily reconnect the battery connector to the motherboard socket. This ensures that the battery is properly aligned in its recess.
[* black] Adhere the battery, disconnect it, and continue reassembling your device.
[* icon_caution] During reassembly, make sure the battery is seated firmly against the rear case. This will prevent any damage to other components when reinstalling the front panel assembly.
[* icon_reminder] Perform a [guide|44495|hard reset|new_window=true] after reassembly. This can prevent several issues and simplify troubleshooting.
