Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 12 guías que incluyan este paso.
Traduciendo paso 3
Paso 3
Removing the battery
Remove the battery.
Adhere the battery, disconnect it, and continue reassembling your device.
[title] Removing the battery |
[* black] Remove the battery. |
[* icon_note] If your replacement battery came in a plastic sleeve, remove it before installation by pulling it away from the the ribbon cable. |
[* icon_reminder] Before you adhere the replacement battery, temporarily reconnect the battery connector to the motherboard socket. This ensures that the battery is properly aligned in its recess. |
[* black] Adhere the battery, disconnect it, and continue reassembling your device. |
[* icon_caution] During reassembly, make sure the battery is seated firmly against the rear case. This will prevent any damage to other components when reinstalling the front panel assembly. |
[* icon_reminder] Perform a [guide|44495|hard reset|new_window=true] after reassembly. This can prevent several issues and simplify troubleshooting. |
