Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 11 guías que incluyen este paso.
Inglés
Español
Paso 3
Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end. Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers. There may be glue around the screw holes that needs to be cut with a knife. Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
  • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
  • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers. There may be glue around the screw holes that needs to be cut with a knife.
  • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
  • Be gentle and keep an eye on the LCD cables as you flip the display over.
  • Lay the LCD on its face to allow access to the display cables.
  • Set the LCD down on a soft, clean, lint-free surface.
Insertar traducción aquí
