Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Traduciendo paso 1
Paso 1
Insert an opening pick between the display frame and the battery. You may need to slide the pick back and forth a few times before it slides into the gap between the frame and the battery. Slide the pick underneath the battery as far as you can while maintaining a firm grip on the pick.
  • Insert an opening pick between the display frame and the battery.
  • You may need to slide the pick back and forth a few times before it slides into the gap between the frame and the battery.
  • Slide the pick underneath the battery as far as you can while maintaining a firm grip on the pick.
  • Slide the pick down the side of the battery to break up the adhesive underneath.
  • Try your best not to deform the battery during this process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
Insertar traducción aquí
