Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Traduciendo paso 5
Paso 5
This is wear the circuits lay. Handle this part carefully, because if you damage this the remote will no longer work. to remove this component simply lift it out of the outer protective shell. This is a series circuits that is controlled by many switches. This part of the remote is the part that reads when you press a button, it then sends a signal to the devices you are trying to make a change on.
Take off the control board
  • This is wear the circuits lay. Handle this part carefully, because if you damage this the remote will no longer work.
  • to remove this component simply lift it out of the outer protective shell.
  • This is a series circuits that is controlled by many switches. This part of the remote is the part that reads when you press a button, it then sends a signal to the devices you are trying to make a change on.
  • To put the remote back together simply put all the layers back on the remote and click the plastic shell back into place.
Insertar traducción aquí
