Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 3
After you open the plastic shell, you will see a silicon layer. These are the buttons that you press in order to send a signal to the TV All you need to do to remove this layer is peel is off. All you need to do to remove this layer is peel is off.
Peel off the Silicon Layer
  • After you open the plastic shell, you will see a silicon layer. These are the buttons that you press in order to send a signal to the TV
  • All you need to do to remove this layer is peel is off.
Insertar traducción aquí
