Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 13 guías que incluyan este paso.
Inglés
Español
Paso 2
Firmly grasp the edge of the midframe assembly. Lift up on the midframe assembly while pushing down on the battery to separate the midframe assembly from the rest of the phone. While lifting the midframe, be careful to avoid snagging it on the audio jack or charging port.
  • Firmly grasp the edge of the midframe assembly.
  • Lift up on the midframe assembly while pushing down on the battery to separate the midframe assembly from the rest of the phone.
  • While lifting the midframe, be careful to avoid snagging it on the audio jack or charging port.
  • Once the midframe is partially seperated, carefully run an opening pick around the edges of the rest of the phone to separate the top of the midframe.
  • To avoid damage to the headphone jack, remove the top of the midframe first, then push the midframe downwards to disengage it from the headphone jack.
  • You may need to heat and apply an iOpener to the edges of the display to soften the display adhesive if midframe separation is difficult.
Sujeta firmemente el borde del conjunto del medio marco.
Levanta el conjunto del medio marco mientras empujas hacia abajo la batería para separar el conjunto del medio marco del resto del teléfono.
Al levantar el medio marco, ten cuidado de evitar el engancharlo en la toma de audio o puerto de carga.
Capaz tendrás que calentar y aplicar el iOpener a los bordes de la pantalla para ablandar el adhesivo de pantalla si el marco medio es difícil.
[* black] Firmly grasp the edge of the midframe assembly.
[* black] Lift up on the midframe assembly while pushing down on the battery to separate the midframe assembly from the rest of the phone.
[* black] While lifting the midframe, be careful to avoid snagging it on the audio jack or charging port.
[* black] Once the midframe is partially seperated, carefully run an opening pick around the edges of the rest of the phone to separate the top of the midframe.
[* black] To avoid damage to the headphone jack, remove the top of the midframe first, then push the midframe downwards to disengage it from the headphone jack.
[* black] You may need to [guide|25705|heat|new_window=true] and apply an iOpener to the edges of the display to soften the display adhesive if midframe separation is difficult.
