Saltar al contenido principal
Inglés
Español
Traduciendo paso 7
Paso 7
Your erasure options are limited to the ATA Security Set supported by your drive. If your drive has ATA Secure Erase implementation problems, choose External. Use ATA Secure Erase on newer drives if possible. Only use Secure Erase on SSD's. Drives without ATA Secure Erase will need to be erased externally. Select a tool in External. For security, select Nwipe with DoD Short. This will erase the drive 3 times and blank it.
(Parted Magic) Erasing hard drives
  • Your erasure options are limited to the ATA Security Set supported by your drive.
  • If your drive has ATA Secure Erase implementation problems, choose External. Use ATA Secure Erase on newer drives if possible. Only use Secure Erase on SSD's.
  • Drives without ATA Secure Erase will need to be erased externally. Select a tool in External. For security, select Nwipe with DoD Short. This will erase the drive 3 times and blank it.
Insertar traducción aquí
