Saltar al contenido principal
Inglés
Español
Paso 5
If this attribute is highlighted, consider a replacement drive.  Use SMART Extended for accuracy. In the Attributes tab, locate the following SMART attributes: Reallocated Sector Count; Reallocation Event Count; Current Pending Sector Count. To test the drive, select Perform Tests. Click Test type: and select Extended Self-Test.
(Parted Magic) Check the reallocated sectors and test the drive
  • If this attribute is highlighted, consider a replacement drive. Use SMART Extended for accuracy.
  • In the Attributes tab, locate the following SMART attributes: Reallocated Sector Count; Reallocation Event Count; Current Pending Sector Count.
  • To test the drive, select Perform Tests. Click Test type: and select Extended Self-Test.
Insertar traducción aquí
