Saltar al contenido principal
Inglés
Español
Paso 3
If this attribute is highlighted, consider a replacement drive.  Use SMART Extended for accuracy. If your drive has run out of spare sectors, the drive capacity will drop. Locate the following SMART attributes: Reallocated sector count; Current pending sector count.
(Ubuntu) Check the reallocated sectors and test the drive
  • If this attribute is highlighted, consider a replacement drive. Use SMART Extended for accuracy.
  • If your drive has run out of spare sectors, the drive capacity will drop.
  • Locate the following SMART attributes: Reallocated sector count; Current pending sector count.
  • To run a SMART Extended Self-Test, left click Start Self-Test. Select Extended from the drop-down menu.
Insertar traducción aquí
