Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 2
Use the flat end of a spudger to gently pry the Lightning connector and speaker enclosure assembly cables up from the rear case. Make sure you get the spudger under the large ribbon cable connected to the assembly. Prying the rest of the assembly away from the cable may result in a tear. Make sure you get the spudger under the large ribbon cable connected to the assembly. Prying the rest of the assembly away from the cable may result in a tear.
  • Use the flat end of a spudger to gently pry the Lightning connector and speaker enclosure assembly cables up from the rear case.
  • Make sure you get the spudger under the large ribbon cable connected to the assembly. Prying the rest of the assembly away from the cable may result in a tear.
Usa el extremo plano de un spudger para levantar los cables del recinto del ensamblaje de conector Lightning y altavoz de la caja trasera.
Asegúrate de colocar el spudger debajo del cable cinta grande conectado al ensamblaje ya que hacer palanca en el resto del ensamblaje podría resultar en una ruptura.
