Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 7
Paso 7
To install a new back cover: Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive.
  • To install a new back cover:
  • Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive.
  • Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
  • If you're reinstalling the old back cover, or using a back cover without adhesive pre-installed, follow this guide.
  • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
  • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it. It won't be waterproof, but the glue is usually more than strong enough to hold.
Para reinstalar la tapa trasera:
Primero utiliza unas pinzas para retirar los restos de adhesivo de la tapa y del cuerpo del teléfono
Después, limpia las áreas de adhesión con alcohol isopropílico (de 90% o más) y un trapo de microfibra. Frota sólo en una dirección, no adelante y atrás. Esto ayudará a preparar la superficie para el nuevo adhesivo.
Asegúrate de encender el teléfono y verificar tu reparación antes de instalar el nuevo adhesivo y volver a sellar el teléfono.
El adhesivo de repuesto viene pre-cortado para coincidir con la tapa trasera, si no está disponible se puede utilizar cinta de doble cara como Tesa 61395. Ten en cuenta que esto dejará espacios que hacen el dispositivo vulnerable a daño por líquidos.
Después de instalar la tapa trasera, aplica presión fuerte y mantenida al dispositivo durante varios minutos para ayudar al adhesivo a que se una bien. Por ejemplo, dejarlo bajo un montón de libros pesados
Si lo deseas, puedes reinstalar la tapa sin sustituir el adhesivo. Retira cualquier gran acumulación de adhesivo que pueda impedir que la cubierta esté nivelada. Después de la instalación, calienta la tapa y aplica presión para asegurarla. No resistirá el agua, pero el adhesivo normalmente es lo suficientemente fuerte como para aguantar
[* icon_reminder] To reinstall theinstall a new back cover:
[* black] First useUse tweezers to peel away any remaining adhesive from both the back cover and the phone's chassis.
[* black] Then,
Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will helpcloth to prep the surface for the new adhesive.
[* black] Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
[* icon_reminder] If you're reinstalling the old back cover, or using a back cover without adhesive pre-installed, [guide|124003|follow this guide|new_window=true].
[* icon_note]
[* icon_note] Replacement adhesive comes in a pre-cut sheet to match the exact contours of the back cover. If that's not available, you can use a high-bond double-sided tape, such as [product|IF317-072|Tesa 61395|new_window=true]. Be aware that this leaves gaps that are vulnerable to liquid intrusion.
[* black] After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
[* black] Then,
[* icon_note]
[* icon_note] If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it. It won't be waterproof, but the glue is usually more than strong enough to hold.
