Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 6
Examine the controllers rubber guards to see if it needs to be replaced or simply needs to be readjusted. If it is damaged, replace the rubber guard with a new one for the correct model, then, proceed to the next step. If not, proceed to the next step. Carefully slide the rubber guard with the area that sticks out more going down into the slot (The crater part of the rubber guard should be in place for the R2/L2 slots; see picture for directions). Once in place, ensure it is snugged and secure.
  • Examine the controllers rubber guards to see if it needs to be replaced or simply needs to be readjusted. If it is damaged, replace the rubber guard with a new one for the correct model, then, proceed to the next step. If not, proceed to the next step.
  • Carefully slide the rubber guard with the area that sticks out more going down into the slot (The crater part of the rubber guard should be in place for the R2/L2 slots; see picture for directions). Once in place, ensure it is snugged and secure.
Examine los protectores de goma de los controladores para ver si necesita ser reemplazado o si simplemente necesita reajustarse. Si está dañado, reemplace el protector de goma con uno nuevo para el modelo correcto, luego, continúe con el siguiente paso. Si no, continúe con el siguiente paso.
Deslice con cuidado el protector de goma con el área que sobresale más hacia abajo en la ranura (la parte de la abertura del protector de goma debe estar en su lugar para las ranuras R2 / L2; consulte la imagen para obtener instrucciones). Una vez en su lugar, asegúrese de que esté ajustado y seguro.
