Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Remove the three 6mm PH2 phillips head screws. Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out. Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
  • Remove the three 6mm PH2 phillips head screws.
  • Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
Insertar traducción aquí
