Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 3
Insert a plastic opening tool in the split at the bottom of the phone (between the bottom shield and the rest of the phone). Pry the bottom shield to separate it from the phone. Once it is loose you should be able to remove it with your hand.
  • Insert a plastic opening tool in the split at the bottom of the phone (between the bottom shield and the rest of the phone).
  • Pry the bottom shield to separate it from the phone.
  • Once it is loose you should be able to remove it with your hand.
Insertar traducción aquí
