Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 6 guías que incluyan este paso.
Inglés
Español
Paso 2
Loosen the two 6.35 mm size 1 Phillips screws on the back cover. The two screws are spring loaded and will not separate from the cover. Slide the back cover towards you and then  lift upwards to remove.
  • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
  • The two screws are spring loaded and will not separate from the cover.
  • Slide the back cover towards you and then lift upwards to remove.
Insertar traducción aquí
