Saltar al contenido principal
Inglés
Español
Paso 5
No hay imagen
Floppy Drive
  • Using a T-8 torx driver, remove the two floppy drive screws.
  • Using a small flat-blade screwdriver, pry up the cable end of the floppy drive and slide the drive to the left.
  • Slide the drive forward slightly and lift it partway out of the unit.
  • Disconnect the floppy drive cable from the motherboard and remove the drive.
  • If you are replacing the floppy drive or floppy drive cable, release the locking tabs and disconnect the cable from the drive.
Insertar traducción aquí
