Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
No hay imagen
  • Make sure your device is completely powered off, then start by placing you tablet face down and remove the charge port cover at the bottom of your tablet
  • Next, place the pry tool in between the black plastic and the back cover of the tablet. Run the pry tool along the edge until the plastic can be removed
  • Once the plastic cover is removed, using the same tool, pry off the headphone cover and switch cover on both sides of the tablet.
  • Using the screwdriver provided in the kit, remove all 10 screws on the back of the tablet
  • place the tablet facing upward and place the pry tool in between the screen and the back cover at the top left corner. Run the pry tool along the edge until the back cover can be removed.
  • Place the tablet facing down and using the pry tool, carefully, remove both wires that are crossing the battery from their ports.
  • Remove the small piece of tape (along with the wire that is connected to the tape) that is connect to the battery in the upper left hand corner of the battery.
  • Next, remove any screws that are holding the battery in place
Insertar traducción aquí
