Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 10 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive. Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in. If the adhesive is hard to cut, use an iOpener to loosen it.
  • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
  • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
  • If the adhesive is hard to cut, use an iOpener to loosen it.
Introduce la punta de una púa de apertura entre la tapa trasera y el marco medio y deslízala alrededor del teléfono para cortar el adhesivo.
Si el adhesivo es difícil de cortar, usa un iOpener para ablandarlo.
[* black] Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
[* black] Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
[* icon_note] If the adhesive is hard to cut, [guide|11677|use an iOpener] to loosen it.
