Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up. Pull the chip directly out from its connectors.
  • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  • Pull the chip directly out from its connectors.
  • If there is a second RAM chip installed, pop it out in the same manner.
  • If you need to mount the logic board back into the heat sink, we have a thermal paste guide that makes replacing the thermal compound easy.
Insertar traducción aquí
