Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 5
Paso 5
Remove the two 4mm screws using a PH0 screwdriver. Depress the tabs holding the battery with a spudger. Disconnect the battery connector from the motherboard using a spudger.
  • Remove the two 4mm screws using a PH0 screwdriver.
  • Depress the tabs holding the battery with a spudger.
  • Disconnect the battery connector from the motherboard using a spudger.
  • Pull the battery up and away from the laptop to remove.
Insertar traducción aquí
