Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 17 guías que incluyan este paso.
Inglés
Español
Paso 4
Carefully slide the flat end of a spudger underneath the display cable to separate the adhesive holding it to the lower case. Take care not to damage the cable. If the adhesive is very strong, heat the case directly beneath the cable with an iOpener to soften the adhesive, and then try again. Take care not to damage the cable. If the adhesive is very strong, heat the case directly beneath the cable with an iOpener to soften the adhesive, and then try again.
  • Carefully slide the flat end of a spudger underneath the display cable to separate the adhesive holding it to the lower case.
  • Take care not to damage the cable. If the adhesive is very strong, heat the case directly beneath the cable with an iOpener to soften the adhesive, and then try again.
Insertar traducción aquí
