Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 25 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
  • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
  • Remove the following eight screws securing the lower case:
  • Two 1.8 mm P5 Pentalobe screws
  • Four 2.9 mm P5 Pentalobe screws
  • Two 6.1 mm P5 Pentalobe screws
  • Note the orientation of the screws as you remove them—they need to be reinstalled at a slight angle.
  • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
Insertar traducción aquí
