Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 25 guías que incluyan este paso.
Inglés
Español
Paso 11
Carefully close the MacBook and flip it over once again, so that the Apple logo faces up. Lifting from the front edge, raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it. Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
  • Carefully close the MacBook and flip it over once again, so that the Apple logo faces up.
  • Lifting from the front edge, raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
  • Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
  • It's possible to open the MacBook all the way and lay both sides down flat, but this may damage the flex cables and is not recommended.
Insertar traducción aquí
