Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 15 guías que incluyan este paso.
Inglés
Español
Paso 2
Carefully lift the secondary hard-drive assembly and then lift the latches to release  the secondary hard-drive cable from the system-board connector. Carefully lift the secondary hard-drive assembly and then lift the latches to release  the secondary hard-drive cable from the system-board connector. Carefully lift the secondary hard-drive assembly and then lift the latches to release  the secondary hard-drive cable from the system-board connector.
Lifting the Secondary Hard-Drive
  • Carefully lift the secondary hard-drive assembly and then lift the latches to release the secondary hard-drive cable from the system-board connector.
Levante con cuidado el conjunto del disco duro secundario y luego levante los pestillos para liberar el cable del disco duro secundario del conector de la placa del sistema.
