Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 2
Remove the screws starting with the three smaller ones on the top part of the battery. Remove the three screws on the other side. There are two screws tucked under where the yellow circle is located. You will need to remove the other screws first before you get to these two.
  • Remove the screws starting with the three smaller ones on the top part of the battery.
  • Remove the three screws on the other side.
  • There are two screws tucked under where the yellow circle is located. You will need to remove the other screws first before you get to these two.
  • There should be one 7 mm Phillips head screw, three 6 mm Phillips head screws, and four 5 mm Phillips head screws.
Insertar traducción aquí
