Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
The motherboard access panel is held on by 4 phillips #2 screws. Remove the screws, then use your fingers to pull on the top tabs to separate the panel from the computer frame. Remove the screws, then use your fingers to pull on the top tabs to separate the panel from the computer frame.
Panel Removal
  • The motherboard access panel is held on by 4 phillips #2 screws.
  • Remove the screws, then use your fingers to pull on the top tabs to separate the panel from the computer frame.
Insertar traducción aquí
