Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
The eMac uses a standard 5.25" IDE optical drive. Most off-the-shelf drives should work as a replacement with minor modification. The jumper setting for the drive should be "CS". Start by disconnecting the IDE and power cables from the drive.
Cable Removal
  • The eMac uses a standard 5.25" IDE optical drive. Most off-the-shelf drives should work as a replacement with minor modification. The jumper setting for the drive should be "CS".
  • Start by disconnecting the IDE and power cables from the drive.
Insertar traducción aquí
