Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
It should be noted that these guides are written based on a late-model eMac (2005, 1.42GHz, DDR). They will differ slightly from the older model eMacs that use PC-133 RAM. Lay the eMac screen-down on a flat surface. I've found it convenient to use a carpeted floor because the computer is so heavy. Remove the single phillips #2 screw on the RAM door, and remove the door
Door Removal
  • It should be noted that these guides are written based on a late-model eMac (2005, 1.42GHz, DDR). They will differ slightly from the older model eMacs that use PC-133 RAM.
  • Lay the eMac screen-down on a flat surface. I've found it convenient to use a carpeted floor because the computer is so heavy.
  • Remove the single phillips #2 screw on the RAM door, and remove the door
  • The screw is captive in the door, so don't worry about losing it.
Insertar traducción aquí
