Saltar al contenido principal
Inglés
Español
Paso 3
3. Dismantle the current, broken zipper on the slider. To do this, you'll need to use pliers - which kind of pliers works best for you . Apply pressure vertically to pry the zipper away from the teeth of the slider.
  • 3. Dismantle the current, broken zipper on the slider. To do this, you'll need to use pliers - which kind of pliers works best for you . Apply pressure vertically to pry the zipper away from the teeth of the slider.
  • Use the other pair of pliers to keep the zipper in place while you remove it. It should then smoothly slide off of the slider.
Insertar traducción aquí
