Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Remove the top two 13mm screws using a screwdriver with the T10 torx bit. Remove the bottom 9mm screw using a screwdriver with the T10 torx bit, and remove the plug port circuit board. Remove the bottom 9mm screw using a screwdriver with the T10 torx bit, and remove the plug port circuit board.
  • Remove the top two 13mm screws using a screwdriver with the T10 torx bit.
  • Remove the bottom 9mm screw using a screwdriver with the T10 torx bit, and remove the plug port circuit board.
Insertar traducción aquí
