Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 9
Paso 9
Tighten the outer two screws along the inner edge of the trackpad and check the alignment of it on the outer side of the upper case.
  • Tighten the outer two screws along the inner edge of the trackpad and check the alignment of it on the outer side of the upper case.
  • If its alignment looks good, install the rest of the Phillips screws along the inner edge of the trackpad.
  • Before reassembling your machine, verify that the set screw is still installed in a position so the mouse will click correctly.
Insertar traducción aquí
