Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Only insert the spudger as deep as 1/16 of an inch to avoid damage. Use a spudger to carefully pry out the loudspeaker. There is some adhesive underneath so it might be a little bit sticky. You can  use an iOpener to loosen it.
  • Only insert the spudger as deep as 1/16 of an inch to avoid damage.
  • Use a spudger to carefully pry out the loudspeaker. There is some adhesive underneath so it might be a little bit sticky. You can use an iOpener to loosen it.
  • Remove the loudspeaker.
  • When reassembling your phone, apply new adhesive where it's necessary.
Insertar traducción aquí
