Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 11 guías que incluyan este paso.
Inglés
Español
Paso 2
Insert a plastic opening tool between the display and the case starting at the bottom area of your phone. Carefully pry the display with its parts out of the case. Getting the prying tool in  will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
  • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
  • Carefully pry the display with its parts out of the case.
  • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
  • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
Introduce una herramienta de apertura de plástico y la caja comenzando en el área inferior de tu teléfono.
Levanta con cuidado la pantalla con sus partes fuera de la caja.
Luego de palanquear el extremo inferior, usa la herramienta de apertura para abrir las abrazaderas en ambos lados.
[* black] Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
[* black] Carefully pry the display with its parts out of the case.
[* icon_note] Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
[* black] After you pried out the bottom end, use the opening tool to open the clamps on both sides.
