Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 43 guías que incluyan este paso.
Inglés
Español
Paso 17
Only lift the display a few inches—it is still attached to the iMac by data and power cables. With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case. If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
  • Only lift the display a few inches—it is still attached to the iMac by data and power cables.
  • With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case.
  • If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
  • Begin to lift the top of the display up from the frame.
Solo levante la pantalla unas pulgadas; todavía está conectada al iMac mediante cables de datos y alimentación.
Con las tarjetas insertadas como se muestra cerca de las esquinas, gire suavemente las tarjetas para aumentar el espacio entre la pantalla y la carcasa.
Si hay secciones que parecen pegarse y no se separan, deje de girar y use una de las tarjetas para cortar el adhesivo en el área problemática.
Comience a levantar la parte superior de la pantalla desde el marco.
