Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 3
Remove the 6 Tripoint screws holding the case together. Pry the 2 halves apart. Do not force it though, or you may break your GBA.
Lower Case
  • Remove the 6 Tripoint screws holding the case together.
  • Pry the 2 halves apart. Do not force it though, or you may break your GBA.
  • Set the bottom half away for later.
  • Be sure not to lose the small, square nut that hold the battery compartment nut in or else you will not be able to screw the battery compartment in.
Insertar traducción aquí
