Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 9
Pull and remove the final adhesive strip. The strip may fling the battery when it separates from the iPhone, so hold your hand over the battery to secure  it—but don't press down on the battery itself, or the added pressure may cause the adhesive strip to break off underneath the battery. If you removed all four adhesive strips successfully, skip the next step.
  • Pull and remove the final adhesive strip.
  • The strip may fling the battery when it separates from the iPhone, so hold your hand over the battery to secure it—but don't press down on the battery itself, or the added pressure may cause the adhesive strip to break off underneath the battery.
  • If you removed all four adhesive strips successfully, skip the next step.
  • If the adhesive breaks off underneath the battery and can't be retrieved, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery in the area of the broken adhesive strip(s).
  • Wait about one minute for the alcohol solution to weaken the adhesive. Use the flat end of a spudger to gently lift the battery.
  • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
  • Be careful not to damage the ribbon cables or the wireless charging coil directly underneath the battery.
  • For alternative methods to unstick the battery from the case, continue to the next step below.
Jala y remueve la tira adhesiva final.
La tira podría golpear la batería cuando se separa del iPhone, así que mantén la mano sobre la batería para protegerla sin presionarla ya que la presión agregada podría hacer que la cinta se rompa por debajo de la batería.
Si has sacado las cuatro tiras adhesiva exitosamente, saltéate el paso siguiente.
Si el adhesivo se rompe debajo de la batería y no puede ser retirado, aplica algunas gotas de alcohol isopropil de alta concentración (arriba de 90%) bajo el borde de la batería en el área de la(s) tira(s) adhesiva(s) rota(s).
