Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 10
If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery. Heat the iPhone until the rear case is slightly too hot to comfortably touch. Don't overheat the iPhone, or you may accidentally ignite the battery.
Alternative method to unstick the battery from the case
  • If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery.
  • Heat the iPhone until the rear case is slightly too hot to comfortably touch. Don't overheat the iPhone, or you may accidentally ignite the battery.
  • Flip the iPhone back over and thread a strong piece of string (such as dental floss or a length of thin guitar string) underneath the battery.
  • Wrap the ends of the string around a cloth (or wear gloves) to protect your fingers.
  • Pull the string from side to side in a sawing motion all along the length of the battery to separate the adhesive. This can take some time since the adhesive is slow to deform, but with patience it will come free. Do not deform or damage the battery.
  • If you choose to use pry tools to lift the battery out of the iPhone, use extreme caution or you may damage the ribbon cables or the wireless charging coil directly underneath the battery.
Si alguna de las tiras adhesivas se rompió y la batería sigue pegada a la caja trasera, prepara un iOpener o usa un secador de pelo para calentar la caja trasera directamente detrás de la batería.
Calentar el iPhone hasta que la caja trasera esté ligeramente muy caliente al tacto. No sobrecalientes el iPhone o podrías accidentalmente prender fuego a la batería.
Voltea el teléfono y pasa un hilo (como hilo dental o una cuerda de guitarra) por debajo de la batería.
Coloca los extremos del hilo alrededor de un paño (o usa guantes) para protegerte los dedos.
Tira del hilo de lado a lado como si estuviera serruchando algo por el largo de la batería para separar el adhesivo. Esto puede llevar algo de tiempo ya que el adhesivo tarde en deformarse pero con paciencia se liberará . No deformes o dañes la batería.
Si eliges utilizar herramientas para palanquear para levantar la batería del teléfono, utiliza precaución extrema porque podrías dañar los cables planos o la bobina de carga inalámbrica directamente por debajo de la batería.
