Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 4
In the following steps, you'll pull each tab to slowly stretch out the adhesive underneath the battery. This special stretch-release adhesive loses its tack when stretched and then comes out in your hand, allowing you to lift out the battery with ease. If the strips break, don't panic! They don't always work as intended. Keep reading for some additional steps for removing broken strips. To increase your odds of success:
  • In the following steps, you'll pull each tab to slowly stretch out the adhesive underneath the battery. This special stretch-release adhesive loses its tack when stretched and then comes out in your hand, allowing you to lift out the battery with ease.
  • If the strips break, don't panic! They don't always work as intended. Keep reading for some additional steps for removing broken strips.
  • To increase your odds of success:
  • Don't press down on the battery. Hold the iPhone firmly by its sides.
  • Keep the strips flat and unwrinkled as you pull.
  • Pull very slowly, giving the strip time to stretch and separate. It takes around 15-30 seconds of stretching to remove each strip.
  • Pull at a low angle so the strip doesn't snag along the bottom edge of the battery.
  • If a strip does break off underneath the battery and cannot be retrieved, move on to the other strips and then continue with the additional steps below.
En los siguientes pasos, tirarás de cada lengüeta para estirar lentamente el adhesivo que se encuentra bajo la batería. Este adhesivo especial que se estira y libera pierde su pegamento cuando se lo estira y se sale en tu mano permitiéndote levantar la batería con facilidad.
Si las tiras se rompen, no te preocupes. No siempre funcionan como deben. Sigue leyendo los pasos adicionales para remover tiras rotas.
Para aumentar las posibilidades de éxito:
No presiones la batería. Sujeta el iPhone firmemente de sus lados.
Mantén las tiras planas y sin arrugas mientras tiras.
Tira muy lentamente, dándole tiempo a la cinta para que se estira y separe. Lleva 15-30 segundos de estiramiento para remover cada tira.
Tira en ángulo bajo así la tira no se rompe a lo largo del borde inferior de la batería.
Si la tira se rompe por debajo de la batería y no se puede recuperar, dirígete a las otras tiras y luego continúa con los pasos adicionales que siguen.
