Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
Insert the flat end of the nylon spudger underneath the black lock. Unlock the ribbon cable by pulling up on the lock with the nylon spudger.
  • Insert the flat end of the nylon spudger underneath the black lock.
  • Unlock the ribbon cable by pulling up on the lock with the nylon spudger.
  • Separate the rear facing camera from the board by pulling gently towards the bottom of the phone.
Inserta el extremo plano de la spudger de náilon debajo de la cerradura negra.
Desbloquea el cable plano tirando de la cerradura con el spudger de náilon.
Separa la cámara de la placa tirando suavemente hacia la parte inferior del teléfono.
[* black] Insert the flat end of the nylon spudger underneath the black lock.
[* black] Unlock the ribbon cable by pulling up on the lock with the nylon spudger.
[* black] Separate the rear facing camera from the board by pulling gently towards the bottom of the phone.
