Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 6 guías que incluyan este paso.
Inglés
Español
Paso 2
Wedge the plastic opening tool between the gap created by separating the screen and body of the phone in the right hand corner to hold it open. Insert the nylon spudger into the lower left corner of the screen and pry the screen toward you. Continue to insert the plastic opening and spudger tools around the phone, and pry open the screen until it is fully separated from the device.
  • Wedge the plastic opening tool between the gap created by separating the screen and body of the phone in the right hand corner to hold it open.
  • Insert the nylon spudger into the lower left corner of the screen and pry the screen toward you.
  • Continue to insert the plastic opening and spudger tools around the phone, and pry open the screen until it is fully separated from the device.
  • It is possible to pry the display assembly apart at this step. Be sure to get the prying instruments underneath both the LCD and screen layers of the display assembly to ensure this separation does not occur.
Calzar la herramienta de apertura de plástico en el espacio creado separando la pantalla y el cuerpo del teléfono en la esquina derecha para mantener la abertura.
Inserta el spudger de nailon en la esquina inferior izquierda de la pantalla y levanta la pantalla hacia ti.
Continúa insertando las herramientas de plástico de apertura y spudger alrededor del teléfono y abre la pantalla hasta que esté completamente separada del dispositivo.
Remueve la pantalla con cuidado y lentamente ya que la pantalla podría agrietarse de lo contrario.
[* black] Wedge the plastic opening tool between the gap created by separating the screen and body of the phone in the right hand corner to hold it open.
[* black] Insert the nylon spudger into the lower left corner of the screen and pry the screen toward you.
[* black] Continue to insert the plastic opening and spudger tools around the phone, and pry open the screen until it is fully separated from the device.
[* icon_caution] RemoveIt is possible to pry the screen gently and slowly asdisplay assembly apart at this step. Be sure to get the prying instruments underneath both the LCD and screen may crack otherwiselayers of the display assembly to ensure this separation does not occur.
