Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 13 guías que incluyan este paso.
Inglés
Español
Paso 7
Slide the pick around the bottom-left corner and along the bottom of the phone. Keep pick at a slight angle away from the screen to avoid damage to the OLED corners. Take extra care not to insert the opening pick more than 9 mm to avoid damaging the OLED panel. Take extra care not to insert the opening pick more than 9 mm to avoid damaging the OLED panel.
  • Slide the pick around the bottom-left corner and along the bottom of the phone. Keep pick at a slight angle away from the screen to avoid damage to the OLED corners.
  • Take extra care not to insert the opening pick more than 9 mm to avoid damaging the OLED panel.
Desliza la púa alrededor de la esquina inferior izquierda y a lo largo de la parte inferior del teléfono.
Ten mucho cuidado de no insertar el pico de apertura más de 9 mm para evitar dañar el panel OLED.
