Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Español
Paso 2
Fill a plastic dropper or syringe with high concentration isopropyl alcohol and apply a few drops of alcohol under each corner of the battery. Give the alcohol a minute to weaken the battery adhesive.
  • Fill a plastic dropper or syringe with high concentration isopropyl alcohol and apply a few drops of alcohol under each corner of the battery. Give the alcohol a minute to weaken the battery adhesive.
  • Alternatively, apply a heated iOpener to the back of the phone over the battery for at least two minutes. Reheat and reapply the iOpener as needed until the battery adhesive is sufficiently weakened.
Si está disponible, aplica algo de alcohol isopropílico debajo de cada esquina de la batería y espera varios minutos para que penetre y ayude a ablandar el adhesivo.
Alternativamente, aplica un iOpener calentado en la parte posterior del teléfono sobre la batería durante al menos dos minutos. Recalienta y vuelve a aplicar el iOpener según sea necesario hasta que el adhesivo de la batería esté lo suficientemente debilitado.
[* black] If available,Fill a plastic dropper or syringe with high concentration isopropyl alcohol and apply some isopropyla few drops of alcohol under each corner of the battery and allow itbattery. Give the alcohol a minute to penetrate for several minutes to help weaken the battery adhesive.
[* black] Alternatively, apply a [guide|11677|heated iOpener|new_window=true] to the back of the phone over the battery for at least two minutes. Reheat and reapply the iOpener as needed until the battery adhesive is sufficiently weakened.
