Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 8 guías que incluyan este paso.
Inglés
Español
Paso 20
At this point it's a good idea to test your repair, in order to make sure your iMac works properly before you seal it back up. Follow the next three steps to temporarily reconnect the display cables and boot up your iMac prior to pulling the protective film off the adhesive strips. If you've already verified that your iMac is working correctly and are ready to seal it up, skip the next step.
Test the display
  • At this point it's a good idea to test your repair, in order to make sure your iMac works properly before you seal it back up. Follow the next three steps to temporarily reconnect the display cables and boot up your iMac prior to pulling the protective film off the adhesive strips.
  • If you've already verified that your iMac is working correctly and are ready to seal it up, skip the next step.
  • Insert the display power cable into its socket on the logic board.
En este punto es una buena idea probar la reparación, para asegurarse de que la iMac funciona correctamente antes de volver a sellarla. Sigue los siguientes tres pasos para reconectar temporalmente los cables de la pantalla y arrancar tu iMac antes de retirar la película protectora de las tiras adhesivas.
Si ya has verificado que tu iMac funciona correctamente y estás listo para sellarlo, salta el siguiente paso.
Inserta el cable de encendido de pantalla en su zócalo en la placa lógica.
