Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 2
Slide the tip of an opening pick under the lower edge of the battery Slowly push the pick in halfway to loosen the adhesive. Insert another opening pick alongside the first pick, and slowly press it in until the adhesive releases the battery.
Loosen the battery
  • Slide the tip of an opening pick under the lower edge of the battery
  • Slowly push the pick in halfway to loosen the adhesive.
  • Insert another opening pick alongside the first pick, and slowly press it in until the adhesive releases the battery.
  • If you are having trouble, you can apply some high-concentration (over 90%) isopropyl alcohol along the battery edges to help soften the adhesive.
Insertar traducción aquí
[title] Loosen the battery
[* black] Slide the tip of an opening pick under the lower edge of the battery
[* black] Slowly push the pick in halfway to loosen the adhesive.
[* black] Insert another opening pick alongside the first pick, and slowly press it in until the adhesive releases the battery.
[* icon_note] If you are having trouble, you can apply some high-concentration (over 90%) isopropyl alcohol along the battery edges to help soften the adhesive.
