Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
If your replacement part did not come with a lower microphone gasket, use tweezers to carefully peel it from your old screen and transfer it to your replacement part.
Remove the microphone gasket
  • If your replacement part did not come with a lower microphone gasket, use tweezers to carefully peel it from your old screen and transfer it to your replacement part.
  • Compare your new replacement screen to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Insertar traducción aquí
[title] Remove the microphone gasket
[* black] If your replacement part did not come with a lower microphone gasket, use tweezers to carefully peel it from your old screen and transfer it to your replacement part.
[* icon_note] Compare your new replacement screen to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
