Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 5
Our X-ray intelligence showed us some screws under the foot, so we concentrated our fire on the adhesive holding it down. Only after some serious heat-gunning were we able to slowly peel the foot up and off. Even knowing the screws are there, we're prepared for the worst, after that gooey chore... ...but are relieved to find those repair-friendly Torx screws ready to unscrew. Also under the glue-foot is a 14-pin port, probably used to test or program HomePods on Pogo pins during assembly.
  • Our X-ray intelligence showed us some screws under the foot, so we concentrated our fire on the adhesive holding it down. Only after some serious heat-gunning were we able to slowly peel the foot up and off.
  • Even knowing the screws are there, we're prepared for the worst, after that gooey chore...
  • ...but are relieved to find those repair-friendly Torx screws ready to unscrew. Also under the glue-foot is a 14-pin port, probably used to test or program HomePods on Pogo pins during assembly.
Nuestra inteligencia de rayos X nos mostró unos tornillos debajo del pie, así que concentramos nuestro fuego en el adhesivo que lo sujeta. Solo después de un disparo de calor serio pudimos despegar el pie lentamente.
Incluso sabiendo que los tornillos están allí, estamos preparados para lo peor, después de la tarea pegajosa.
…pero se siente alivio de encontrar los tornillos Torx fáciles de reparar listos para desenroscar. También bajo el pie del pegamento hay un puerto de 14 pines, que probablemente se utiliza para probar o programar los HomePod en los pines pogo durante el ensamblaje.
