Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 8 guías que incluyen este paso.
Inglés
Español
Paso 5
Cut a strip of 1 mm wide double-sided tape to be about 3 cm long (1.25 inches). Lay the adhesive strip along the upper edge of the earpiece speaker slot in your new display so that it's centered over the slot and touching the upper edge. The adhesive strip needs to be as close as possible to the edge of the slot without overlapping.
  • Cut a strip of 1 mm wide double-sided tape to be about 3 cm long (1.25 inches).
  • Lay the adhesive strip along the upper edge of the earpiece speaker slot in your new display so that it's centered over the slot and touching the upper edge.
  • The adhesive strip needs to be as close as possible to the edge of the slot without overlapping.
  • Gently press the adhesive strip into place on the display with your finger or a spudger.
  • Repeat this step to apply a second, identical adhesive strip along the bottom edge of the speaker slot.
  • Peel the white backing away from both adhesive strips.
Corta una tira de adhesivo de 1 mm de ancho y 6 mm de largo.
Coloca la tira de adhesivo a lo largo del borde superior de la ranura del altavoz auricular en tu pantalla nueva para que esté centrada sobre la ranura y toque el borde superior.
La tira adhesiva necesita estar lo más cerca posible del borde de la ranura sin superponerse.
Presiona suavemente la tira adhesiva en su lugar en la pantalla con tu dedo o un spudger.
Repite este paso para aplicar una segunda tira adhesiva idéntica a lo largo del borde inferior de la ranura del altavoz.
Despega el respaldo blanco de ambas tiras adhesivas.
