Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 8 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
If your replacement display did not come with pre-installed speaker grilles or a front-facing camera bracket, carefully remove these parts from your old display. Follow the rest of the guide to install them on a new display. To remove the camera bracket, apply heat, then use a thin metal blade to pry the bracket away from the old screen.
  • If your replacement display did not come with pre-installed speaker grilles or a front-facing camera bracket, carefully remove these parts from your old display. Follow the rest of the guide to install them on a new display.
  • To remove the camera bracket, apply heat, then use a thin metal blade to pry the bracket away from the old screen.
  • There are two layers that make up the speaker grille—the metal mesh grille, and a layer of thin fabric mesh behind it. Use tweezers to peel both layers off of the old screen together. Do your best to not separate those layers at all.
  • Make sure to install the grilles and gasket before applying display adhesive.
  • Cut two corners of a pre-cut adhesive card so that each side is no more than 12 mm (0.5 inches) long, or cut four 12 mm (0.5 inches) strips of double-sided adhesive.
  • The adhesive strips should be no wider than 1 mm.
  • Apply the adhesive strips to the edges of the flat side of the front-facing camera bracket. When you're done, there should be adhesive on all four edges of the camera bracket.
  • Gently press the adhesive into place using your finger or a spudger.
Si tu pantalla de reemplazo no vino con las rejillas del altavoz preinstaladas o una junta de cámara frontal, remueve con cuidado estas partes de tu pantalla vieja. Sigue el resto de la guía para instalarlas en la pantalla nueva.
Para remover el soporte de cámara, aplica calor, luego usa una cuchilla de metal delgada para hacer palanca y sacarla de la pantalla vieja.
Hay dos capas que componen la rejilla del altavoz: la rejilla de malla metálica y una capa de malla delgada de tela detrás de ella. Usa pinzas para despegar las dos capas de la pantalla antigua. Haz tu mejor esfuerzo para no separar esas capas en absoluto.
Asegúrate de instalar las rejillas y junta antes de aplicar adhesivo en la pantalla.
Corta dos esquinas de una tarjeta adhesiva pre-cortada de forma tal que cada lado tenga un largo de no más de 12 mm o corta cuatro tiras de adhesivo de cara de 12 mm.
Las tiras adhesivas deben tener un ancho de no más de 1 mm.
Aplica las tiras adhesivas en los bordes del lado plano del soporte de la cámara frontal. Cuando hayas terminado, tendría que haber adhesivo en todos los cuatro bordes del soporte de la cámara.
Con cuidado presiona el adhesivo en su lugar utilizando tu dedo o un spudger.
