Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 13 guías que incluyan este paso.
Inglés
Español
Paso 2
Pull up on the suction cup with firm, constant pressure and insert an opening pick between the front panel and rear case. Do not insert the pick deeper than 1.5 mm, or you risk damaging the OLED panel. This requires a significant amount of force and patience. If you have trouble, rock the suction cup and screen to weaken the adhesive, or apply heat with an iOpener,  heat gun, or hair dryer.
  • Pull up on the suction cup with firm, constant pressure and insert an opening pick between the front panel and rear case.
  • Do not insert the pick deeper than 1.5 mm, or you risk damaging the OLED panel.
  • This requires a significant amount of force and patience. If you have trouble, rock the suction cup and screen to weaken the adhesive, or apply heat with an iOpener, heat gun, or hair dryer.
  • The display panel is fragile. If you plan to re-use your display, take care to insert your tool only as far as necessary to separate the adhesive. Inserting the tool any further can damage the OLED panel under the glass.
Tira de la ventosa con presión constante y firme e inserta una púa de apertura entre el panel frontal y caja trasera.
Esto requiere una gran cantidad de fuerza y paciencia. Si tienes problemas, mueve la ventosa y pantalla para ablandar el adhesivo o aplicar calor con una pistola de calor, iOpener o secador de pelo.
El panel de visualización es frágil. Si planeas reutilizar su pantalla, ten cuidado de insertar tu herramienta solo lo necesario para separar el adhesivo. Insertar la herramienta más puede dañar el panel OLED debajo del vidrio.
[* black] Pull up on the suction cup with firm, constant pressure and insert an opening pick between the front panel and rear case.
[* icon_caution] Do not insert the pick deeper than 1.5 mm, or you risk damaging the OLED panel.
[* icon_note] This requires a significant amount of force and patience. If you have trouble, rock the suction cup and screen to weaken the adhesive, or apply heat with an iOpener, heat gun, or hair dryer.
[* icon_caution] The display panel is fragile. If you plan to re-use your display, take care to insert your tool only as far as necessary to separate the adhesive. Inserting the tool any further can damage the OLED panel under the glass.
